Tagged: 19, Design Assessment, mechanical, structural-mechanics, User Defined
April 5, 2023 at 2:32 pm
FAQParticipantThere is no direct option to use exp(x) or e(x) in User Define Results expressions. You will have to define it as; (2.71828**(x)) or (2.71828^(x)) For more details on other expressions and their syntax, you can check following page on ANSYS/Help, help/wb_sim/ds_user_defined_express.html
