The PGWRITE command seems to cause ANSYS to spontaneously abort after issuing SOLVE (well before going into /POST1 and using the Results Viewer). I never see anything more than a zero-byte filename.pgr in the current directory. What is casing this?
Tagged: 17, General, mechanical-apdl, structural-mechanics
May 15, 2023 at 8:32 am
Solution
ParticipantPlease refer to the attachment(s) to access the Solution.
1. 299117.pdf
