The nodal coordinates printed back by ResRdDemo are not consistent with the coordinates printed with NLIST. Can you tell me what is going on in ResRdDemo?
May 15, 2023 at 8:32 am
SolutionParticipantPlease refer to the attachment(s) to access the Solution.
1. 438047.pdf
