May 15, 2023 at 8:32 am
SolutionParticipantSpaceClaim allows direct editing of STL mesh files. The attached video demonstrates SpaceClaim’s mesh manipulation capabilities.
1. 2052895.zip
2. 2052895_Captions-EN.mp4
