Tagged: 17.2, fluent, fluid-dynamics, MP - Particle Tracking, multiphase, phase-change
March 17, 2023 at 1:11 pm
Solution
ParticipantIn applications such as Spray dryers, users often need to capture the rate of drying process and its efficiency. In general, for such applications, particles are often made of two or components, where in one component (water) needs to be evaporated from the mixture. For dilute systems, lagrangian particle tracking approach can be used to capture drying phenomena. This solution explains how to set up such cases.
1. 2046025.pdf
2. 2046025.zip
- Solver message during DPM calculation: “number of stepsize underflows during particle integration step is x”. What does it mean and how to get rid of it?
- What is the difference between the VOF model and the Eulerian model?
- ANSYS Fluent – Eulerian & Mixture Multiphase Models & Applications – Tips and Tricks
- ANSYS Fluent: Efficient Modeling of Spray Breakup using VOF-to-DPM Transition
- What is the superficial velocity in multiphase flows?
- Mixing Tank Modeling in ANSYS Fluent
- Hydrodynamics and Wave Impact Analysis
- ANSYS Fluent: Describing Cavitation in a Centrifugal Pump
- How do I use porous media in a multiphase flow?
- What do “incomplete” DPM particle tracks mean?
