Should the participation factors reported in the mode coefficient table after a spectrum analysis always be positive?
March 17, 2023 at 9:00 am
FAQParticipantNo. The sign has an equal probability of being positive and negative. The participation factor is used to determine how much of the mass of a certain mode is moving in the same direction as the excitation. The excitation direction is defined in a spectrum analysis with the SED command. The participation factor formula given in Theory Manual is the mode shape transposed times the mass matrix times a vector of ones that are associated with the direction of excitation. The negative of a mode shape is a valid solution, so the participation factor can be negative. The effective mass of a mode is its participation factor squared.
- How to setup Initial, Minimum and Maximum time step in Transient analysis?
- In a random vibration analysis, what is “GRMS” and how can it be calculated?
- In Workbench Mechanical, how can I obtain strain energy output for Modal analysis?
- How to define variable thickness shell elements in ANSYS Mechanical? Is there any verification example of the variable thickness shell modal analysis available?
- How to apply application-based settings to improve the performance and robustness of transient structural analyses?
- In the results of a modal analysis, how can I define that a frequency is an output parameter ?
- How to include effect of bolt pretension in a modal analysis?
- How to resolve the “General solver failure” error while running a rigid body dynamics analysis?
- Tips about Postprocessing options for Harmonic Solution in Mechanical
- ANSYS Explicit Dynamics: Using Joints, Joint Loads and Probes
