Should the damping coefficients alpha and beta have units? They seem to be unitless in Workbench Mechanical.
June 5, 2023 at 7:05 am
FAQ
ParticipantYes, in Workbench Mechanical, the alpha and beta damping coefficients should have units of [s] and [s^-1] since they are of the following form: [C] = alpha * [M] + beta * [K]. This is reflected in two locations – in the Engineering Data (Damping Factor (alpha) and (beta)) and in WB Mechanical (Analysis Settings branch, under “Damping > Stiffness/Mass Coefficient). This should be corrected in future releases.
- How to setup Initial, Minimum and Maximum time step in Transient analysis?
- In Workbench Mechanical, how can I obtain strain energy output for Modal analysis?
- How to define variable thickness shell elements in ANSYS Mechanical? Is there any verification example of the variable thickness shell modal analysis available?
- How to apply application-based settings to improve the performance and robustness of transient structural analyses?
- Why is damped frequency is lower than undamped frequency with viscous damping but larger with structural damping?
- In the results of a modal analysis, how can I define that a frequency is an output parameter ?
- How to include effect of bolt pretension in a modal analysis?
- In a random vibration analysis, what is “GRMS” and how can it be calculated?
- How can I specify acceleration at a node? Could I use the ‘big mass method’?
- Presentation on shock analysis using response spectrum and transient dynamics
