September 26, 2022 at 9:53 am
FAQParticipantResolving license error – Your version of the ANSYS license client software is out of date.
Error:
Following error might be seen while trying to launch Discovery/SpaceClaim:
Your version of the ANSYS license client software is out of date. Refer to Licensing Error Messages in the Troubleshooting section of the ANSYS Licensing Guide.
The version of the license client
ansysli_client[version] must be greater or equal to the clientANSYS application[version].Recommended solution:
This message indicates that you are attempting to start an ANSYS, Inc. application with an out-of-date version of the license client.
If you are using different installation directories for the current and prior versions, you need to ensure that each version is running from the appropriate installation directory.
If you are using the same installation directory for the current version as you used for the prior version, try the following solutions:
- The license client was running during the installation process and was not replaced. In this case, close all ANSYS, Inc. applications, making sure that the license client closes, and then run the Complete Unfinished Licensing Installation Configuration option from the Client ANSLIC_ADMIN’s Tools menu.
- The license client was running during the installation process and was replaced, but the application is not reading the new client. In this case, close all ANSYS, Inc. applications, making sure that the license client closes, and restart the ANSYS, Inc. application.
- Ansys Discovery Hardware Requirements (2025 R2)
- What’s New in Ansys Discovery 2025 R2
- Discovery License Activation Troubleshooting
- Resolving Error “QA services environment variable is enabled” while opening Discovery products
- FAQ: Resolving Error – ANSYSLI exited or could not read server port ANSYSLI_FNE_PORT
- Changing Named User Subscription or Floating (Enterprise) license option after installation of Discovery products
- Discovery Subscription license – Command line options
- Discovery Family Licensing & Installation
- Discovery: Black screen with no geometry appears after launching Discovery
- ANSYS Discovery: Compatibility Utility
