September 26, 2022 at 9:53 am
FAQParticipantResolving error “Org is null” on Administration page
Problem: When you log into your Discovery account and click Administration tab, you might see error “Org is null”.
Cause: While the problem is being investigated, this seems to be an issue with detecting company information.
Recommended solution: Refreshing the browser cache should resolve the issue. Do a force update by pressing Ctrl + F5 on the Administration page, this should clear your cache and allow the updated page to display correctly.
- Ansys Discovery Hardware Requirements (2026 R1)
- What’s New in Ansys Discovery 2026 R1
- Discovery License Activation Troubleshooting
- Resolving Error “QA services environment variable is enabled” while opening Discovery products
- FAQ: Resolving Error – ANSYSLI exited or could not read server port ANSYSLI_FNE_PORT
- Changing Named User Subscription or Floating (Enterprise) license option after installation of Discovery products
- Discovery Subscription license – Command line options
- Discovery: Black screen with no geometry appears after launching Discovery
- Discovery Licensing Options
- ANSYS Discovery: Compatibility Utility
