September 26, 2022 at 9:53 am
FAQ
ParticipantProblem: During installation of Discovery 2019R1 version, the following error is observed in “install.err” file (saved at C:Program FilesANSYS Inc or equivalent Discovery products installation folder)
Cause: This error is due to a defect with the German localization. It is fixed for release 2019 R2.Recommended solution: To overcome the above-mentioned problem, install Product Installation Service Pack for German language OS from Discovery Downloads page.
Alternatively, you can also manually edit one file from 2019R1 installation to overcome this error. Below are the steps:
In the file:
..Shared FilesLicensinglicadminscriptslanguagede.msg localization, it seems the %s entries where changed to %1 for the following localized string:
mcset de “Processing %s file required by the %s file”
“Verarbeitung der Datei %1 ist erforderlich aufgrund der Datei %1”
These lines should be:
“Verarbeitung der Datei %s ist erforderlich aufgrund der Datei %s”
To correct the issue, after installation you must edit de.msg (right click on this file and open in any text editor for editing) so it reads %s and NOT %1.
After that, you must run this command from an adimistrator command prompt:
- Ansys Discovery Hardware Requirements (2025 R1)
- What’s New in Ansys Discovery 2025 R1
- Discovery License Activation Troubleshooting
- Resolving Error “QA services environment variable is enabled” while opening Discovery products
- FAQ: Resolving Error – ANSYSLI exited or could not read server port ANSYSLI_FNE_PORT
- Discovery Subscription license – Command line options
- Discovery Family Licensing & Installation
- Changing Named User Subscription or Floating (Enterprise) license option after installation of Discovery products
- ANSYS Discovery: Compatibility Utility
- Discovery: Black screen with no geometry appears after launching Discovery
