May 15, 2023 at 8:32 am
SolutionParticipantEdges and surfaces can be replaced in SpaceClaim. The attached video demonstrates how to use the Replace Faces tool and the Trim tool to edit geometry in SpaceClaim.
1. Replace%20and%20Trim.mp4
