Regarding Semi Implicit Solver Technology, is there any limit to the number of times the code will switch from implicit to semi implicit solver and back again?
April 5, 2023 at 2:31 pm
FAQ
ParticipantNo. Code will switch from implicit to semi implicit solver whenever convergence failure occurs in pure implicit. There is no limit to the number of times this can happen.
- How to setup Initial, Minimum and Maximum time step in Transient analysis?
- In Workbench Mechanical, how can I obtain strain energy output for Modal analysis?
- How to define variable thickness shell elements in ANSYS Mechanical? Is there any verification example of the variable thickness shell modal analysis available?
- How to apply application-based settings to improve the performance and robustness of transient structural analyses?
- Why is damped frequency is lower than undamped frequency with viscous damping but larger with structural damping?
- In the results of a modal analysis, how can I define that a frequency is an output parameter ?
- How to include effect of bolt pretension in a modal analysis?
- How can I specify acceleration at a node? Could I use the ‘big mass method’?
- Presentation on shock analysis using response spectrum and transient dynamics
- In a random vibration analysis, what is “GRMS” and how can it be calculated?
