Regarding AMPOWDER command, why is the entry for the powder convection coefficient different from the value entered in the details window for AM Process =>Build Setting?
March 17, 2023 at 9:00 am
FAQParticipantThe difference in convection coefficient is likely due to a unit conversion from what’s displayed in Mechanical (W/mm^2C) to the solving units (tons/second3 * degree Celsius). Here’s a link to the doc on solving units: https://ansyshelp.ansys.com/account/secured?returnurl=/Views/Secured/corp/v195/wb_sim/ds_solving_units.html%23ds_tbl_filmcoef
