March 17, 2023 at 8:59 am
FAQParticipantThis can be due to version compatibility issues between SpaceClaim and CAD. If the CAD has newer version than the supported version for SpaceClaim, it can give such error of “No B-Rep data”. To resolve this, try to have newer version of SpaceClaim that is compatible with the given version of CAD. Please check following link for supported versions. https://www.ansys.com/Solutions/Solutions-by-Role/IT-Professionals/Platform-Support
