August 25, 2023 at 12:16 pm
SolutionParticipantTo re-orient the move handle you can use the reference entities such as faces/ edges etc. Press ALT button + select face/edge in the direction of orientation Please refer to the attachment to access the solution
1. 2045547.mp4
