July 4, 2022 at 6:59 am
Watch & Learn
ParticipantThis signal integrity video explores unwanted mode conversion, from differential signal to common signal, due to unbalanced ground return current via paths in a multilayer differential pair simulated in HFSS 3D Layout. Starting at 1:35, the video shows how to move a differential pair, including the port, from one lower layer up to another layer in one operation. At 2:46 the video describes the engineering relation between asymmetry and mode conversion in terms of mixed mode S-parameters. The HFSS 3D Layout unbalanced (asymmetric) design, with a ground return path via missing, is created after 4:58. The change to an HFSS fully arbitrary 3D (FA3D) design starts at 7:19, with the symmetrical S-parameters shown at 8:34. The asymmetrical (unbalanced) FA3D design consideration starts at 9:14
- How do I calculate inductance and resistance of a coil in post-processing phase?
- How to create and manage a queue of simulations?
- Are solid losses and eddy losses the same in Maxwell?
- How to enable GPU acceleration in Electronics Desktop?
- Electric Motor Design Using Ansys Motor-CAD – Part 1
- How to import/export an Ansys Maxwell model in Workbench?
- How to calculate capacitance and inductance in Maxwell Transient solver?
- What are the available boundary conditions in Maxwell?
- How to fix messed up Windows layout?
- How to perform a material sweep?
