Modal analysis does not do modal participation factor. Gives following *** NOTE *** The .full file does not exist by user request. Participation factor calculations will be skipped. How to get modal participation factor ?
June 5, 2023 at 7:05 am
FAQParticipantLooks like PCG Lanczos modal solver triggered this. Solution to this problem is insert PCGOPT ,,,,, ON command through a Command snippet under Modal Analysis. This should allow the solver to write .full file and participation factor calculation. I would suggest you to go through PCGOPT and MSAVE command help manual page to get more information on this.
- How to setup Initial, Minimum and Maximum time step in Transient analysis?
- In a random vibration analysis, what is “GRMS” and how can it be calculated?
- In Workbench Mechanical, how can I obtain strain energy output for Modal analysis?
- How to define variable thickness shell elements in ANSYS Mechanical? Is there any verification example of the variable thickness shell modal analysis available?
- How to apply application-based settings to improve the performance and robustness of transient structural analyses?
- In the results of a modal analysis, how can I define that a frequency is an output parameter ?
- How to include effect of bolt pretension in a modal analysis?
- How to resolve the “General solver failure” error while running a rigid body dynamics analysis?
- Tips about Postprocessing options for Harmonic Solution in Mechanical
- ANSYS Explicit Dynamics: Using Joints, Joint Loads and Probes
