May 15, 2023 at 8:32 am
SolutionParticipantSometimes files created by other CAD softwares import into SpaceClaim with missing faces and/or gaps. The attached video demonstrates how to fix those missing faces to create a watertight solid as well as show how to remove rounds.
1. 2052898.mp4
2. 2052898.zip
