September 26, 2022 at 9:33 am
FAQParticipantSpaceClaim
No known issues, limitations, or documentation inaccuracies.
Ansys Discovery
- The presence of monitors on points, planes, lines and surfaces may cause a design variant solution to fail. (560005)
- In the Explore stage, when solving for results that exhibit highly localized extrema, monitors on points, planes, lines and surfaces may deviate from the underlying solution. Workaround: The legend and corresponding min/max monitors in the volume would yield the most accurate information on the global extrema. (554884)
- When using the opacity slider in Display tab > Color, the assigned body or face color may be substituted with black.Workaround: To change the opacity of a body or a face, define an override color first then adjust the opacity as needed. (552013)
- After solving in Refine, projects exported to Mechanical may not contain tabular data.Workaround: Export to Mechanical before solving. (552234)
- When working with physics parameters in test cases and then navigating to another simulation, the test cases may no longer be visible.Workaround: Un-parameterize your physics parameter and then re-parameterize it (using undo). (552575)
- If a simulation containing a porous condition is duplicated, thermal properties for the porous material are not retained when the project is saved.Workaround: Replace the porous condition in the duplicate simulation after opening the saved project. (552181)
- Discovery Downloads
- Ansys Discovery – Supported File Formats
- Release Notes- Previous versions
- Importing an Autodesk Fusion 360 Design Study into Ansys Discovery
- Ansys Discovery: Transient Simulation
- Top New Features in Ansys Discovery 2026 R1
- Ansys Discovery: Creating Custom Shortcuts
- Ansys Discovery: Customizing the Ribbon Tab
- Discovery SpaceClaim – Scripting examples
- Ansys Discovery 2025 R1 Capabilities chart
