It appears that there are some problems in the current viscoelastic model (ANSYS v.61-v8.1), that could be confusing to ANSYS users. (1) For TB,Prony input, the data can be entered at different temperatures. I believe that the Prony constants are a function of reference temperature instead of temperature. Because, under each reference, the Prony pairs are obtained based on the master curve which is generated by time-temperature superposition based on modulus-frequency curves at different temperature. Therefore, Prony pairs has already considered different temperature. Why does the design of the Prony Table include different temperature again? I believe that will certainly confuse users. (2) For the Shift function, there should be only one group C1, C2 and Tref input. However, if you use a different Tref, the C1, C2 should be different and should generate a shift factor A(T) that is quite different. What is the significance of a different Tref?
Tagged: 17, hyperelasticity, materials, mechanical-apdl, PRONY, structural-mechanics
March 17, 2023 at 1:11 pm
SolutionParticipantPlease refer to the attachment(s) to access the Solution.
1. 318568.pdf
- Question: What is the difference between PLNSOL, EPPL, EQV and PLNSOL,NL,EPEQ?
- For the stress-life fatigue method, how are the Goodman and Gerber mean stress theories used to modify the calculated stress amplitude in the Workbench Fatigue Module?
- How to use layered section to simulate composites and post process the results in ANSYS Mechanical
- ANSYS Mechanical: Delamination Analysis using Contact Debonding
- Guidelines of modeling a gasket.
- How do I move a material property from Engineering Data to an existing Material Library?
- Why is the unit of the elastic foundation stiffness N/m^3?
- In the Mechanical Fatigue Tool, what is the calculated safety factor?
- Hyperelastic Simulations
- What are Isochronous stress-strain curves? How can they be used in ANSYS for modeling creep?
