Is viscoelasticity (TB,PRONY) equivalent to frequency-dependent structural damping (TB,SDAMP) in a harmonic response analysis?
January 25, 2023 at 7:34 am
FAQParticipantIt is possible to define complex moduli with TB,PRONY that gives the same displacement response as frequency-dependent stiffness (TB,ELASTIC) and damping (TB,SDAMP). However, the stress results will differ since viscoelasticity considers the complex moduli in its stress calculations – in the ANSYS Help Viewer, see Section 4.7.3.4 “Stress” in “Mechanical APDL > Material Reference > 4. Nonlinear Material Properties > 4.7 Viscoelasticity > 4.7.3 Harmonic Viscoelasticity” for details. With frequency-dependent stiffness and damping, the elastic modulus is considered to be a real quantity, so there will not be any phase difference between stress and strain.
- How to setup Initial, Minimum and Maximum time step in Transient analysis?
- How to define variable thickness shell elements in ANSYS Mechanical? Is there any verification example of the variable thickness shell modal analysis available?
- In Workbench Mechanical, how can I obtain strain energy output for Modal analysis?
- In a random vibration analysis, what is “GRMS” and how can it be calculated?
- How to apply application-based settings to improve the performance and robustness of transient structural analyses?
- Why is damped frequency is lower than undamped frequency with viscous damping but larger with structural damping?
- How to include effect of bolt pretension in a modal analysis?
- In the results of a modal analysis, how can I define that a frequency is an output parameter ?
- ANSYS Explicit Dynamics: Using Joints, Joint Loads and Probes
- Snap Fit Analysis – Best Practices
