Tagged: 18, analysis-techniques, mechanical, optimization, structural-mechanics
April 13, 2023 at 7:32 am
SolutionParticipantYes, It is possible to do. please refer the below attachments. 2D_Bracket_topoopt_multiple_loadcases_v18.pdf – Example setup procedure L_SHAPE_V18_combined_loads.wbpz
1. 2049115.zip
2. 2D_Bracket_topoopt_multiple_loadcases_v18.pdf
