January 25, 2023 at 7:34 am
FAQParticipantYou need to start by generating cyclic test data of your material application and from the test data, determine what effects (i.e. shakedown, ratcheting) need to be modeled. From there, you can use some of the guidelines found in Chapter 5 of the Advanced Structural Nonlinear Course notes for choosing the right combination of hardening models in Chaboche to start your curve fitting. ANSYS does not currently offer tools or training expertise in the area of curve fitting for this material model. The material model involves two physics associated with kinematic hardening and isotropic hardening. They are in turn described by two sets of parameters. A correct procedure would be to carefully set up experiments to separate the two behaviors, such that curve fitting can be performed with each one. We can’t use a uniaxial tensile test to get the parameters out of it such as we do for hyperelasticity, since it is the mixed behavior from the two hardenings. Also, kinematic hardening itself has several variations, so it is hard to establish a unique experimental set up. It will depend on what the test lab can do. Hence, user needs to consult with a reputable test lab (Datapoint Labs or Axel Products). Refer also to Mechanics of Solid Materials by Lemaitre & Chaboche, English Translation by Cambridge University Press, 1990.
- Question: What is the difference between PLNSOL, EPPL, EQV and PLNSOL,NL,EPEQ?
- For the stress-life fatigue method, how are the Goodman and Gerber mean stress theories used to modify the calculated stress amplitude in the Workbench Fatigue Module?
- How to use layered section to simulate composites and post process the results in ANSYS Mechanical
- ANSYS Mechanical: Delamination Analysis using Contact Debonding
- Guidelines of modeling a gasket.
- How do I move a material property from Engineering Data to an existing Material Library?
- Why is the unit of the elastic foundation stiffness N/m^3?
- In the Mechanical Fatigue Tool, what is the calculated safety factor?
- Hyperelastic Simulations
- What are Isochronous stress-strain curves? How can they be used in ANSYS for modeling creep?
