Is there a way to use a custom crack growth equation (Walker, Forman, NASGRO, etc)? The reason is that I already have those material constants.
Tagged: 2020 R2, fracture, materials, mechanical, structural-mechanics
January 25, 2023 at 7:34 am
FAQ
ParticipantSince Release 2020R2, you can also use the Walker equation and also Forman equation instead of just Paris’ law as a crack growth law. And you can define the crack growth law material parameters as temperature dependent values. It is currently not possible to define your own custom crack equation in equation form. BUT, also since 2020R2, you can define the crack growth law in TABULAR FORM (with linear interpolation between the data points in the log-log space). Further details you will find in the ANSYS Help at https://ansyshelp.ansys.com/account/secured?returnurl=/Views/Secured/corp/v202/en/ans_frac/franundcgrowmech.html and https://ansyshelp.ansys.com/account/secured?returnurl=/Views/Secured/corp/v202/en/ans_frac/fracSMART.html .
- Question: What is the difference between PLNSOL, EPPL, EQV and PLNSOL,NL,EPEQ?
- How to use layered section to simulate composites and post process the results in ANSYS Mechanical
- Guidelines of modeling a gasket.
- ANSYS Mechanical: Delamination Analysis using Contact Debonding
- For the stress-life fatigue method, how are the Goodman and Gerber mean stress theories used to modify the calculated stress amplitude in the Workbench Fatigue Module?
- Why is the unit of the elastic foundation stiffness N/m^3?
- How do I move a material property from Engineering Data to an existing Material Library?
- What are Isochronous stress-strain curves? How can they be used in ANSYS for modeling creep?
- How do I enter major Poisson’s ratio in ANSYS Mechanical?
- Hyperelastic Simulations
