Is there a way to restart an AM simulation that was deliberately set to build only a user specified number of layers per Section .11 of ANSYS_Workbench_Additive_Manufacturing_Analysis_Guide?
March 17, 2023 at 9:00 am
FAQParticipantMid-build restarts aren’t enabled right now. However, if you’re using inherent strain you can use the inistate command to apply different strain values to different regions and then build like normal.
