Is there a way to re-use the reduced matrices to solve more loading histories in a reduced transient analysis?
March 17, 2023 at 9:00 am
FAQParticipantA CMS Superelement to do the matrix reduction could be re-used in a full transient. An advantage of this approach is that a CMS Superelement will provide a more accurate dynamic representation of the reduced structure than the Guyan Reduction used in a reduced transient. Also, a CMS Superelement can be generated using the Sparse solver, which is much faster than the frontal solver used to perform the matrix reduction in a reduced transient.
- How to setup Initial, Minimum and Maximum time step in Transient analysis?
- In a random vibration analysis, what is “GRMS” and how can it be calculated?
- In Workbench Mechanical, how can I obtain strain energy output for Modal analysis?
- How to define variable thickness shell elements in ANSYS Mechanical? Is there any verification example of the variable thickness shell modal analysis available?
- How to apply application-based settings to improve the performance and robustness of transient structural analyses?
- In the results of a modal analysis, how can I define that a frequency is an output parameter ?
- How to include effect of bolt pretension in a modal analysis?
- How to resolve the “General solver failure” error while running a rigid body dynamics analysis?
- Tips about Postprocessing options for Harmonic Solution in Mechanical
- ANSYS Explicit Dynamics: Using Joints, Joint Loads and Probes
