Is there a way to obtain integration point results for new elements (such as solid186)? Looking for a way to output these results as could be done for Solid95 (via Keyopt).
Tagged: 18.1, General, mechanical, structural-mechanics
June 5, 2023 at 7:05 am
FAQParticipantOne can issue the command ERESX,NO in PREP7 prior to solving then use PRESOL command to output unaveraged element results. This will give the integration point values for those integration points nearest to the node location. Also one may use the INISTATE command for the same. Following is the Syntax of the command to be used: INISTATE, WRITE, FLAG, , , , CSID, Dtype
