Is there a way to extract acceleration frequency response in a harmonic analysis directly from Mechanical APDL?
April 5, 2023 at 2:33 pm
FAQParticipantThe only way to get acceleration frequency response in Mechanical APDL is to derive it from the nodal displacements using NSOL and PROD commands in /POST26 (e.g., multiply displacements by 2*pi*freq (i) to get velocity). Velocity and acceleration in harmonic analysis are not stored in the result file, so the user needs to obtain the nodal displacement using the NSOL and PROD commands. The reason we do not store velocities and acceleration in a harmonic analysis is because in Mechanical APDL we would like to be efficient in writing the result file and avoid storing dependent variables to save space. Also, it is just one additional line of code to calculate the velocity or acceleration variable in post26. (In Workbench Mechanical, when acceleration frequency response plot is added in the results, we are just calculating acceleration using nodal displacement post solution.) Additional Note: Since ANSYS performs a smoothing operation on accelerations in a transient analysis, they are stored by the solver (see OUTRES command) and can be obtained using the NSOL command directly.
- How to setup Initial, Minimum and Maximum time step in Transient analysis?
- In a random vibration analysis, what is “GRMS” and how can it be calculated?
- In Workbench Mechanical, how can I obtain strain energy output for Modal analysis?
- How to define variable thickness shell elements in ANSYS Mechanical? Is there any verification example of the variable thickness shell modal analysis available?
- How to apply application-based settings to improve the performance and robustness of transient structural analyses?
- In the results of a modal analysis, how can I define that a frequency is an output parameter ?
- How to include effect of bolt pretension in a modal analysis?
- How to resolve the “General solver failure” error while running a rigid body dynamics analysis?
- Tips about Postprocessing options for Harmonic Solution in Mechanical
- ANSYS Explicit Dynamics: Using Joints, Joint Loads and Probes
