Tagged: 2020 R2, fracture, materials, mechanical, structural-mechanics
March 17, 2023 at 9:00 am
FAQParticipantUsually, reducing the buffer zone factor is not desirable, especially in a SMART crack growth analysis. However, the buffer zone reference size depends on the bounding box of the arbitrary crack geometry (surface body). Keep the arbitrary crack geometry as small as possible to keep the buffer zone reference size to a minimum. But the buffer zone factor cannot be reduce to a value less than 2.
- Question: What is the difference between PLNSOL, EPPL, EQV and PLNSOL,NL,EPEQ?
- How to use layered section to simulate composites and post process the results in ANSYS Mechanical
- For the stress-life fatigue method, how are the Goodman and Gerber mean stress theories used to modify the calculated stress amplitude in the Workbench Fatigue Module?
- Guidelines of modeling a gasket.
- ANSYS Mechanical: Delamination Analysis using Contact Debonding
- How do I move a material property from Engineering Data to an existing Material Library?
- Why is the unit of the elastic foundation stiffness N/m^3?
- In the Mechanical Fatigue Tool, what is the calculated safety factor?
- Hyperelastic Simulations
- What are Isochronous stress-strain curves? How can they be used in ANSYS for modeling creep?
