Tagged: 19, apdl, Macros/Scripting/UPF, mechanical-apdl, structural-mechanics
April 5, 2023 at 2:33 pm
FAQParticipantYes, at 19.0, the array/table is limited to 1 million cells. For tables that does not include the indices so a 1 million row table can be edited. The underlying command is *VEDIT but the limit is not mentioned there.
