Is there a functionality in DesignModeler to stop/interrupt hanging or long-lasting operations. Some operations, for instance, ShareTopology are sometimes observed to hang in conjunction with complex cases?
Tagged: 18.1, Create Geometry, designmodeler, Other, structural-mechanics
June 5, 2023 at 7:05 am
FAQParticipantNo, currently ti is not possible to stop or interrupt DM operation. However from WB one can stop (kill) the DM session and recover the previously saved DM session when opens the DM again.
