Is there a command to extract the sum of forces after calling PRRSOL (similar to using *GET after FSUM) in Mechanical APDL?
June 6, 2022 at 9:58 am
FAQParticipantThere is not such a command to continue PRRSOL. You may consider getting the reaction forces from constrained nodes. To get sum of reaction force of multiple nodes use the *GET command with a *Do loop.
