Is the USUM value from a PSD analysis correct? I know there are certain derived quantities that should not be computed from the 1-sigma components (for example, s1).
March 17, 2023 at 9:00 am
FAQParticipantUSUM is calculated from the 1-sigma components of displacement. It should be reasonably accurate because the calculation of USUM doesn’t dependent on the sign of the components. It is still somewhat conservative as it assumes the components are in-phase. A check on the calculation could be done in /POST26 by computing an RPSD of USUM for some location using a variable which was the SRSS combination of the component displacements. The square root of the integral of the USUM RPSD should match the /POST1 1-sigma value.
- How to setup Initial, Minimum and Maximum time step in Transient analysis?
- In a random vibration analysis, what is “GRMS” and how can it be calculated?
- In Workbench Mechanical, how can I obtain strain energy output for Modal analysis?
- How to define variable thickness shell elements in ANSYS Mechanical? Is there any verification example of the variable thickness shell modal analysis available?
- How to apply application-based settings to improve the performance and robustness of transient structural analyses?
- In the results of a modal analysis, how can I define that a frequency is an output parameter ?
- How to include effect of bolt pretension in a modal analysis?
- How to resolve the “General solver failure” error while running a rigid body dynamics analysis?
- Tips about Postprocessing options for Harmonic Solution in Mechanical
- ANSYS Explicit Dynamics: Using Joints, Joint Loads and Probes
