Tagged: 19.2, acoustics, mechanical, structural-mechanics
April 5, 2023 at 2:32 pm
FAQParticipantThe acoustics capability in ANSYS Mechanical is solving the linear wave equation (also known as the modified Helmholtz equation), so everything is linear.
