Is nodal displacement solved for each node in F= KX equation> If yes then how results are interpreted at intermediate points?
- If yes then how results are interpreted at intermediate points?" target="_blank" rel="nofollow" title="LinkedIn">
- If yes then how results are interpreted at intermediate points?" target="_blank" rel="nofollow" title="whatsapp">
- If yes then how results are interpreted at intermediate points?" target="_blank" rel="nofollow" title="reddit">
- If yes then how results are interpreted at intermediate points?" target="_blank" rel="nofollow" title="facebook">
Tagged: 18, General, mechanical, structural-mechanics
April 5, 2023 at 2:32 pm
FAQParticipantYes the displacements are nodal one and the results at intermediate locates are interpolated using shape functions.
