Is it possible to use angular velocity vs. time output from a Rigid dynamics solve as an input for a joint in a another rigid dynamics solve?
Tagged: 19, mechanical, structural-dynamics, structural-mechanics
May 15, 2023 at 8:33 am
SolutionParticipantPlease refer the attachments to access the solution
1. 2053178-b.pdf
2. 2053178.zip
- How to setup Initial, Minimum and Maximum time step in Transient analysis?
- In a random vibration analysis, what is “GRMS” and how can it be calculated?
- In Workbench Mechanical, how can I obtain strain energy output for Modal analysis?
- How to define variable thickness shell elements in ANSYS Mechanical? Is there any verification example of the variable thickness shell modal analysis available?
- How to apply application-based settings to improve the performance and robustness of transient structural analyses?
- In the results of a modal analysis, how can I define that a frequency is an output parameter ?
- How to include effect of bolt pretension in a modal analysis?
- How to resolve the “General solver failure” error while running a rigid body dynamics analysis?
- Tips about Postprocessing options for Harmonic Solution in Mechanical
- ANSYS Explicit Dynamics: Using Joints, Joint Loads and Probes
