Is it possible to update Design Points without resolving ANSYS Mechanical? For example, if a new post-processing item is requested after the Design Points were obtained, all data in the parameter tab will be shown as out-of-date.
June 5, 2023 at 7:04 am
FAQParticipantNo. The observed behavior is by design. It cannot be overridden. Mechanical does not identify to the Parameter Manager what action was done, so the Parameter Manager must require a resolve, because the action might have been something critical (e.g., a new mesh).
