Is it possible to transfer the displacement boundary condition from Random Vibration PSD analysis to Nonlinear static analysis ?
August 25, 2023 at 12:16 pm
Solution
ParticipantYes, Refer attachments for the procedure.
1. 2048882.pdf
2. 2048882.zip
- In Workbench Mechanical, how can I obtain strain energy output for Modal analysis?
- How to define variable thickness shell elements in ANSYS Mechanical? Is there any verification example of the variable thickness shell modal analysis available?
- How to setup Initial, Minimum and Maximum time step in Transient analysis?
- Why is damped frequency is lower than undamped frequency with viscous damping but larger with structural damping?
- How to apply application-based settings to improve the performance and robustness of transient structural analyses?
- In the results of a modal analysis, how can I define that a frequency is an output parameter ?
- How to include effect of bolt pretension in a modal analysis?
- How can I specify acceleration at a node? Could I use the ‘big mass method’?
- Presentation on shock analysis using response spectrum and transient dynamics
- In a Modal Analysis of Mechanical, why aren’t the Participation Factors Summary under Solution Information displayed?
