Is it possible to transfer temperature distribution from a solid model thermal analysis to a shell model -structural analysis?
May 15, 2023 at 8:32 am
SolutionParticipantIt is not native in Mechanical but can be achieved with external data and the shell thickness factor. See attachments
1. 2049484-b.pdf
2. 2049484.pdf
3. 2049484.zip
