March 17, 2023 at 9:00 am
FAQParticipantNegative creep is not possible. We trap this in the material algorithms and limit the creep increment to be positive. Negative swelling is possible. The creep swelling can be a function of the material state such as stress and creep strain – just like the deviatoric creep. In MAPDL we only have deviatoric creep behavior. Our swelling is similar to thermal strain and it can’t be a function of the current material state such as stress and creep strain, but user could probably implement a user swelling model that was a function of the material state from the previous substep.
- Question: What is the difference between PLNSOL, EPPL, EQV and PLNSOL,NL,EPEQ?
- For the stress-life fatigue method, how are the Goodman and Gerber mean stress theories used to modify the calculated stress amplitude in the Workbench Fatigue Module?
- How to use layered section to simulate composites and post process the results in ANSYS Mechanical
- ANSYS Mechanical: Delamination Analysis using Contact Debonding
- Guidelines of modeling a gasket.
- How do I move a material property from Engineering Data to an existing Material Library?
- Why is the unit of the elastic foundation stiffness N/m^3?
- In the Mechanical Fatigue Tool, what is the calculated safety factor?
- Hyperelastic Simulations
- What are Isochronous stress-strain curves? How can they be used in ANSYS for modeling creep?
