Is it possible to recover DesignModeler geometry files from a hard crash, for example, if there was a blackout and all equipment shutdown?
June 6, 2022 at 9:58 am
FAQParticipantYou can try the following approach:
Open File Explorer and enter %temp% in the command line and then search for file type *agdb. You should see several files with names like:
XXXX.agdb-0
XXXX.agdb-1
XXXX.agdb-2
XXXX.agdb-3
The DesignModeler Auto-save feature creates these files. You can review these files to determine the latest saved version.
