Is it possible to plot the topology density result with more contour bands (beyond the standard three (Remove (red), Marginal (yellow) and Keep (grey)?
Tagged: 18, analysis-techniques, mechanical, optimization, structural-mechanics
March 17, 2023 at 8:59 am
FAQParticipantIt is possible via UDR (User Defined Results) in Version 18 using types: ETOPO and TOPO.
