Is it possible to plot the statistical average frequency used by the Steinberg method in the Mechanical Fatigue Tool?
Tagged: 2019 R2, fatigue, materials, mechanical, structural-mechanics
March 17, 2023 at 1:11 pm
SolutionParticipantNot directly, but you can obtain and plot it using user defined results. The statistical average frequency is defined as: [1/(2*pi)*(velocity/displacement)]. You can extract the displacement as one user-defined result and the velocity as another user-defined result. You can then calculate the statistical average frequency as another user-defined result using the displacement and velocity user-defined results. The displacement is the first moment of the stress term. The velocity is the second moment. Thus, for example, you can calculate the statistical average frequency for 1-sigma equivalent stress (SPSD) by extracting the displacement (first moment) as a user-defined result and the velocity (second moment) as another user-defined result. You can then create a third user-defined result using the expression: [1/(2*pi)*(velocity/displacement)]. You can then plot the statistical average frequency user-defined result. See attached test model.
1. 2060374.zip
- Question: What is the difference between PLNSOL, EPPL, EQV and PLNSOL,NL,EPEQ?
- For the stress-life fatigue method, how are the Goodman and Gerber mean stress theories used to modify the calculated stress amplitude in the Workbench Fatigue Module?
- How to use layered section to simulate composites and post process the results in ANSYS Mechanical
- ANSYS Mechanical: Delamination Analysis using Contact Debonding
- Guidelines of modeling a gasket.
- How do I move a material property from Engineering Data to an existing Material Library?
- Why is the unit of the elastic foundation stiffness N/m^3?
- In the Mechanical Fatigue Tool, what is the calculated safety factor?
- Hyperelastic Simulations
- What are Isochronous stress-strain curves? How can they be used in ANSYS for modeling creep?
