March 17, 2023 at 9:00 am
FAQParticipantIn ANSYS Release 11.0, it is not possible to plot principal stresses from a PSD analysis. The capability to plot of principal stresses from a PSD analysis was removed in Release 8.1. The stress components from PSD analyses are 1-sigma results, so they do not have an associated sign. Using these statistical stress components to calculate derived stress quantities is not appropriate. The equivalent stress (SEQV) is determined using the Segalman-Reese approach, which considers the probability distribution of equivalent stress. The Segalman-Reese approach does not cover principal stresses.
- How to setup Initial, Minimum and Maximum time step in Transient analysis?
- How to define variable thickness shell elements in ANSYS Mechanical? Is there any verification example of the variable thickness shell modal analysis available?
- In Workbench Mechanical, how can I obtain strain energy output for Modal analysis?
- In a random vibration analysis, what is “GRMS” and how can it be calculated?
- Why is damped frequency is lower than undamped frequency with viscous damping but larger with structural damping?
- How to apply application-based settings to improve the performance and robustness of transient structural analyses?
- How to include effect of bolt pretension in a modal analysis?
- In the results of a modal analysis, how can I define that a frequency is an output parameter ?
- Presentation on shock analysis using response spectrum and transient dynamics
- ANSYS Explicit Dynamics: Using Joints, Joint Loads and Probes
