Is it possible to perform a sine-on-random vibration analysis in either Mechanical or Mechanical APDL?
January 25, 2023 at 7:34 am
FAQParticipantNeither Mechanical nor Mechanical APDL provides an automated method for performing a sine-on-random vibration analysis. A harmonic response analysis is deterministic (real + imaginary results), where as a random vibration analysis is statistical (1-sigma results). So, it is not clear how to combine the results. Two methods employed sometimes employed to simulate the sine-on-random effect are: 1. Include the harmonic loading (sine) as a ‘spike’ in the PSD input spectrum (area of sine loading should have same energy content) and then perform a single combined PSD analysis. 2. Perform a separate harmonic response and random vibration analysis and convert the harmonic response results to “RMS”” values. Then statistically add the RMS results from the harmonic analysis to random vibration results.
- How to setup Initial, Minimum and Maximum time step in Transient analysis?
- How to define variable thickness shell elements in ANSYS Mechanical? Is there any verification example of the variable thickness shell modal analysis available?
- In Workbench Mechanical, how can I obtain strain energy output for Modal analysis?
- In a random vibration analysis, what is “GRMS” and how can it be calculated?
- How to apply application-based settings to improve the performance and robustness of transient structural analyses?
- In the results of a modal analysis, how can I define that a frequency is an output parameter ?
- How to include effect of bolt pretension in a modal analysis?
- Why is damped frequency is lower than undamped frequency with viscous damping but larger with structural damping?
- How to resolve the “General solver failure” error while running a rigid body dynamics analysis?
- ANSYS Explicit Dynamics: Using Joints, Joint Loads and Probes
