Is it possible to map keys on the keyboard to ANSYS commands to create shortcuts for frequently used commands?
Tagged: 17, apdl, Macros/Scripting/UPF, mechanical-apdl, structural-mechanics
May 15, 2023 at 8:32 am
SolutionParticipantPlease refer to the attachment(s) to access the Solution.
1. 317330.pdf
