Tagged: 19.2, acoustics, mechanical, structural-mechanics
April 5, 2023 at 2:32 pm
FAQParticipantIt is not possible to have acoustic material properties as a function of pressure since, in acoustics, we are solving the Helmholtz equation, which is linear. Consequently, any nonlinearities (including pressure-dependent material properties or modeling cavitation) is not possible.
