Is it possible to generate a response spectrum in directly from an array parameter of acceleration vs. time without using a model?
January 25, 2023 at 7:34 am
FAQ
ParticipantYes. You have to create at least one dummy node, but otherwise the input below creates a response spectrum from array parameters. ! creation of a response spectrum from a time history stored in ! array parameters var1 (time) and var2 (data) the array parameter ! freq contains the frequencies to be computed *dim,var1,,20 ! store input in 2 array parameters *dim,var2,,20 *dim,freq,,30 ! time points of time-history (could *VREAD) *vfil,var1(1),ramp,.001,.001 *stat,var1 *vfil,var2(1),ramp,0,0 ! data of time-history (could *VREAD) var2(10)=1 ! create impulse time history – should produce flat unit spectrum *stat,var2 *vfil,freq(1),ramp,5,1 ! frequencies 5, 6, … , 34 *stat,var3 /prep7 ! make a dummy model n,1 fini /post26 store,alloc,30 ! allocate the number of time points vput,var1(1),1 ! vput the array parameters into post26 variables vput,var2(1),3 vput,freq(1),2 prvar,2,3 resp,4,2,3,1,.05,.001 prvar,2,4 ! variable 4 vs 2 is the response spectrum xvar,2 plvar,4
- How to setup Initial, Minimum and Maximum time step in Transient analysis?
- How to define variable thickness shell elements in ANSYS Mechanical? Is there any verification example of the variable thickness shell modal analysis available?
- In Workbench Mechanical, how can I obtain strain energy output for Modal analysis?
- How to apply application-based settings to improve the performance and robustness of transient structural analyses?
- Why is damped frequency is lower than undamped frequency with viscous damping but larger with structural damping?
- In the results of a modal analysis, how can I define that a frequency is an output parameter ?
- How to include effect of bolt pretension in a modal analysis?
- In a random vibration analysis, what is “GRMS” and how can it be calculated?
- How can I specify acceleration at a node? Could I use the ‘big mass method’?
- Presentation on shock analysis using response spectrum and transient dynamics
