Is it possible to extract the element volume fraction associated with a particular integration point?
Tagged: Element volume fraction, integration-point, upf
June 6, 2022 at 9:58 am
FAQParticipantThis information is not available via *GET, but from a User-Programmable Features (UPF), integration point volume is available from get_ElmData() with inquire=’EJAC’, but this isn’t available for post processing.
