January 25, 2023 at 7:34 am
FAQParticipantNo. The acceleration and velocity constraints (D,ACCX and D,VELX, respectively) are valid only for structural static and transient analyses (Basic Guide, Section 2.5). In a harmonic analysis all loads are assumed to vary sinusoidally. You need to integrate the acceleration/velocity load and apply it as a displacement. The integration only requires a simple division. acceleration load (a = acceleration, v = velocity, u = displacement, w = omega = frequency, t = time): a = A sin (wt) v = A/w cos (wt) u = -A/w/w sin (wt) As a result, to apply an acceleration load of magnitude “A”, simply set a displacement constraint with a magnitude of “-A/w/w”.
- How to setup Initial, Minimum and Maximum time step in Transient analysis?
- In a random vibration analysis, what is “GRMS” and how can it be calculated?
- In Workbench Mechanical, how can I obtain strain energy output for Modal analysis?
- How to define variable thickness shell elements in ANSYS Mechanical? Is there any verification example of the variable thickness shell modal analysis available?
- How to apply application-based settings to improve the performance and robustness of transient structural analyses?
- In the results of a modal analysis, how can I define that a frequency is an output parameter ?
- How to include effect of bolt pretension in a modal analysis?
- How to resolve the “General solver failure” error while running a rigid body dynamics analysis?
- Tips about Postprocessing options for Harmonic Solution in Mechanical
- ANSYS Explicit Dynamics: Using Joints, Joint Loads and Probes
